v8dave wrote:The A and B injectors have different flow ratings.
When any injector is changed the engine control will need updating with the new injectors code and then the pump and injector learned values need to be refreshed.
You should ensure that all the injectors have the same part number.
Rebuilt injectors are probably a waste of money unless they come with new correction codes.
v8dave wrote:You should ensure that all the injectors have the same part number.
ryankkm wrote:Need to know asap can anyone tell me if one injector is AC and the rest are BC will that cause my problems?
Do they all have to be BC as the ac one is problbly the one he changed
knobby1 wrote:ryankkm wrote:Need to know asap can anyone tell me if one injector is AC and the rest are BC will that cause my problems?
What PS is your engine..?? As V8Dave has mentioned....the injector part number will depend on the engine PS..! The 2.4 100/115 will be the same Pn... and the 140 will be a different Pn.
Different flow ratings etc...
ryankkm wrote:Got a reconditioned bc one fitted today coded in and correction factors done,
No smoke now and van runs a lot better, slight judder from engine when holding rev between 1500 and 2000 rpm, don't know if that's anything to worry about?
And down on power slightly, mechanic says that the van was mapped before and now it's back to factory settings?? Can that even be done by working at the injectors?
ake wrote:If he did a pcm update it would clear a remap, but based on the fact he doesn't know the difference between injectors, I'd have my doubts
ake wrote:ryankkm wrote:Got a reconditioned bc one fitted today coded in and correction factors done,
loot wrote:I'm confused
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
