350 lwb td P1665 Error
Postby Roshco » Fri Apr 28, 2017 10:21 am
Hi all.
I've been using this forum for some time to fix issues and it's been really helpful. I'm not very good with the issue (electrical stuff) I have at the moment and even my mechanic is struggling.I I parked up the van went to friends, and half an hour later got in the van and it wouldn't start....would just turn over. P1665 injection pump communication error. Main relay power hold. Injection Circuit Fault. Injection timing control circuit....these are the results my mechanic got. I've already sent the pumps module off for inspection and they replaced a corroded transistor, put it back on the pump but it still has the same issues.
I've gone through the forums previous posts and not found anything that stands out. Any help would be greatly appreciated.
Roshco
Re: 350 lwb td P1665 Error
Postby Frag » Sat Apr 29, 2017 9:28 am
To be able to help you,
We could do with knowing what year van,I'm guessing it's a mk 6.
Front or rear wheel drive,and what bhp / ps engine......
Frag
Ford Technician
Users browsing this forum: knobby1
