Fast flashing indicator
Postby Driveconvert » Sat Apr 29, 2017 10:03 am
Hi All
I have a 2006 (MK7) LWB HT RWD Transit
The other day I pulled over and turned off the engine before cancelling the indicator, when I started the van a few minuets later the LH indicator on the dash was flashing very fast and my thinking was a bulb had gone. So I had a look and yes the rear LH indicator was not working so I checked the bulb (the old one is still ok) but I changed it anyway but that one is not working as well? all the other LH indicators are working all be it flashing just as fast as the light on the dash.
Looking at the fuse board there seems to be just one fuse for the indicator? and there is nothing else going on that I can tell...
But I just can not think what it could be?
07 MK7 Transit, LWB HT RWD 2.4l 100hp
Driveconvert
Re: Fast flashing indicator
Postby blue estate » Sat Apr 29, 2017 10:07 am
Take light unit out pull off wiring plug and clean it up as well as bulb holder and check for the evil scotch blocks
72plt MG 5 ev estate Battery car
blue estate
Postby Driveconvert » Sat Apr 29, 2017 10:33 am
Thanks for that I did not think of pulling it all apart. When I did I found all this...
It looks like I need to find a new light cluster, unless that can be cleaned up?
Driveconvert
Postby blue estate » Sat Apr 29, 2017 11:05 am
you can clean it up or just get new one make sure its for a mk7 as the mk6 indicator is straight pin not off sethttp://www.ebay.co.uk/itm/FORD-TRANSIT- ... xy63FSpfvy
blue estate
Postby richgold » Sat Apr 29, 2017 12:32 pm
blue estate wrote:you can clean it up or just get new one make sure its for a mk7 as the mk6 indicator is straight pin not off sethttp://www.ebay.co.uk/itm/FORD-TRANSIT- ... xy63FSpfvy
It's not worth cleaning up, not when a new one is less than £9, you'll only have the same problem again later.
I've had those lamp holders (and lenses too) from TPUK, and they are fine.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby Driveconvert » Sat Apr 29, 2017 3:09 pm
Thanks guys, I was thinking of cleaning it up but given I am not going to be driving the van until next weekend I might as well get a new one and then know it is going to be fine.
Thanks for your help
Driveconvert
Postby motorman116 » Sun Apr 30, 2017 11:22 am
When you get the new light bulb holder, put some Vasoline on the contacts, as it repels water and stops corrosion.
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
