A new starter is not gonna fix the fuel pump Has the pump been changed or the codes read The engine may not have turned over because the alternator was seized from lying up ( does happen quite a lot ) Ps most of us are here to help so go easy on the miracleStevetransit04 wrote:. The van had a lot of easy Start used on it suspected diesel pump failure send van
Sat for 3 months after the 3 months that van would only give a single click when trying to start after I freed the engine using another van and a tow rope 3rd gear the engine now rotates quite easily . That's why I am assuming the engine was only semi see the due to easy start being used and the fact it was sitting for 3 months
0
