Clutch pedal ratchet (AGAIN!)
Postby Smooth Hound » Thu Jul 12, 2007 7:56 pm
pictishpunkgirl here on smooth hound's log in. Changed the clutch pedal ratchet a few weeks ago & it's gone f***ed & come apart. Is there ANY way we could change it to a manually adjusting mechanism? It's a 94 2.5 di so probably too early but I HATE that bloody plastic sh*t. :evil:
'94 L Reg 2.5Di LWB high top
Smooth Hound
Postby V184 » Thu Jul 12, 2007 8:00 pm
You sure its not something else thats making the ratchet slip. if the clips missing off the cable at pedal box end that can cause it or if the clutch is badly worn etc ?
V184
Location: You're right, V184 is an arsehole with a chip on his shoulder........
Postby djswampy » Thu Jul 12, 2007 10:37 pm
You can change it to be a manually adjusting pedal but you need to get the manual bits from a scrap van. You cannot buy the lot from a dealers (So I have been told) but try them anyway.
Mk5 LWB 190, 2.5di banana SHR, 3 seats, SLD, Twin rear doors (rusted bottoms), manual locking & windows. For sale £700, comes with replacement set of doors
djswampy
Location: Colchester. Transit: mk5, '96, 2.5di banana, lwb, semi roof, 190
Postby MrMPuk » Thu Jul 12, 2007 10:38 pm
You can get all the bits from the dealer, there is a kit.
Postby djswampy » Thu Jul 12, 2007 10:45 pm
MrMPuk wrote:You can get all the bits from the dealer, there is a kit.
That's the answer then. Any Idea on the cost of it?
djswampy
Postby Smooth Hound » Fri Jul 13, 2007 11:07 am
V184 wrote:You sure its not something else thats making the ratchet slip. if the clips missing off the cable at pedal box end that can cause it or if the clutch is badly worn etc ?
clip :?:
Smooth Hound
