Hi,
I'm trying to work out why the air conditioning on our mk6 rwd isn't working. The green light on the switch comes on. The clutch doesn't seem to be engaging (I can't see it move). There doesn't seem to be any power across the two contacts on the plug. The engine bay and passenger fuses are OK (thank you for the "MK 6) fuse, relay and diode locations/ratings" thread).
It was previously run dry, but has been fully recharged and pressure tested.
Any pointers on what to try next please? Or a link to a wiring diagram?
Next step for me would be to try to trigger the clutch, but it's a two pin plug and I'm not sure which pin is which.
The wiring loom near the plug has two orange/white wires just cut off bare with no termination. I don't know if that's relevant. The wiring on this van has been heavily customised by a previous owner.
