by blue estate » Sun May 21, 2017 10:26 am
1st is good
2nd ok if its as good in flesh
3rd run forest run
Vehicle make
FORD
Vehicle model
TRANSIT
Date first used
27 November 2007
Fuel type
Diesel
Colour
Blue
MOT history of this vehicle
Test date
28 February 2017
Expiry date
28 February 2018
Test Result
Pass
Odometer reading
147,124 miles
MOT test number
2532 2949 1852
Test date
1 March 2016
Expiry date
28 February 2017
Test Result
Pass
Odometer reading
134,458 miles
MOT test number
6213 9995 0972
Advisory notice item(s)
Front Exhaust has a minor leak of exhaust gases flexy (7.1.2)
Nearside Front Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Test date
24 February 2016
Test Result
Fail
Odometer reading
134,434 miles
MOT test number
5548 6004 3573
Reason(s) for failure
Nearside Front front brake binding (3.7.B.1)
Nearside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Offside Rear Seat belt anchorage prescribed area is excessively corroded (5.2.6)
Nearside Front Suspension component mounting prescribed area is excessively corroded door step (2.4.A.3)
Offside Front Suspension component mounting prescribed area is excessively corroded door step (2.4.A.3)
Test date
25 February 2015
Expiry date
24 February 2016
Test Result
Pass
Odometer reading
86,666 miles
MOT test number
7175 8635 5018
Test date
25 February 2015
Test Result
Fail
Odometer reading
86,666 miles
MOT test number
4457 4645 5071
Nearside Front Front position lamp(s) not working (1.1.A.3b)
Test date
30 January 2014
Expiry date
30 January 2015
Test Result
Pass
Odometer reading
109,662 miles
MOT test number
5180 6063 4096
Test date
27 January 2014
Test Result
Fail
Odometer reading
109,660 miles
MOT test number
2796 3762 4020
Offside Front position lamp(s) not working (1.1.A.3b)
Offside Front Statutory seat belt missing (5.1.1)
Test date
31 January 2013
Expiry date
30 January 2014
Test Result
Pass
Odometer reading
64,125 miles
MOT test number
2479 6113 3004
Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
Offside Front Brake pipe slightly corroded (3.6.B.2c)
Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Tyre worn close to the legal limit (4.1.E.1)
Test date
22 January 2013
Test Result
Fail
Odometer reading
64,125 miles
MOT test number
3486 8222 3086
Nearside Track rod end ball joint has excessive play (2.2.B.1f)
Offside Track rod end ball joint has excessive play (2.2.B.1f)
Offside Rear Leaf spring fractured (2.4.B.1a)
Nearside Front Anti-roll bar linkage ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
Offside Front Anti-roll bar linkage ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
Test date
28 November 2011
Expiry date
27 November 2012
Test Result
Pass
Odometer reading
61,207 miles
MOT test number
8797 2273 1361
Test date
22 November 2010
Expiry date
27 November 2011
Test Result
Pass
Odometer reading
59,005 miles
MOT test number
4520 8622 0322
Search again
Cookies Terms and Conditions
Open Government Licence
72plt MG 5 ev estate Battery car
