ake wrote:If the starter doesn't help, try a crank sensor
Squirell2212 wrote:Went out to move the van to change the starter and it won't start, battery is 12.7volts turn the key and just get one single click like a relay , suspect starters died and this has been the fault ? Or throw another battery on it and see what happens ?
nedforceone wrote:Squirell2212 wrote:Went out to move the van to change the starter and it won't start, battery is 12.7volts turn the key and just get one single click like a relay , suspect starters died and this has been the fault ? Or throw another battery on it and see what happens ?
I would try a starter first. N
