The van is a MK6 2.0 FWD SWB LOW ROOF.
A few months ago I fitted 16 inch wheels with the biggest tyres you could fit ( stupid I know ), Last year I fitted solid flywheel after dual mass blew the clutch plate to bits, new clutch flywheel and csc was fitted.
In the last week when setting off in first gear when the vehicle is under load ( up hill, it never carries weight ) I am finding heavy shuddering / spinning / slipping ( not sure which ) coming from the O/S front, unless I feather the clutch and accelerator.
One garage has told me that the clutch is going and another garage has told me that the clutch is fine, ( neither took it for a drive to see what it was like setting off in first up hill ), checked bearing and drive shaft for play but both fine.
I am confused as to what this problem could be, dont want to pay for a new clutch and find out it is something else.
Any help would be greatly appreciated or anyone local to Leeds that I could come and show the problem.
Thanks.
