by scas » Thu May 25, 2017 3:35 pm
its usually the breather pipe which goes onto the top of the tank then goes to the fuel filler assembly. easiest way to change is loosen the front 2 bolts on the tank and take off the rear 2 that way you can get at it easily
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
