Heater only blowing hot. Tourneo 59
Postby Drive4it » Thu May 25, 2017 3:44 pm
Hi.
The internal heater is only blowing hot.
My mechanic has removed like a square black enclosed swith he says activates the valve.
Hes told me the only way to get one is a new genuine part. £200!!!
Pic attached of what he shown me
Any ideas guys if this sounds right part?
I've tried a few breakers but no luck so far
Drive4it
Re: Heater only blowing hot. Tourneo 59
Postby spencenpc » Wed Jun 07, 2017 7:53 pm
Hi - i'm having the same sort of problem with the temperature not changing - getting stuck - not sure if this is what you are looking at but it's cheaper than your mechanics parthttp://www.ebay.co.uk/itm/FORD-TRANSIT- ... 2006693287
spencenpc
Postby spencenpc » Wed Jun 07, 2017 8:04 pm
also might be worth looking inside that actuator - just found this - might be worth a go if it is just that which is broken
http://www.ebay.co.uk/itm/191063671898? ... rmvSB=true
spencenpc
