by madmart132 » Fri May 26, 2017 12:07 am
Hi mate you don't say what sort of driving you do ?
If its all in central London then ok what would you expect ? My wife has a petrol Fiat Multipla and she struggles to get over 20mpg round town .
If on a run I would expect 25mpg ( I have a Jumbo and thats what I get ) I also have a MK6 petrol Luton and I get 18-22mpg from that but not really a fair comparison there .
Is everthing OK with the engine etc ?
Any fault codes coming up ?
I find even changing the oil can add 1-3 mpg
Are the tyres at the correct pressures ? that is a real killer for the MPG on these vans .
Does it have LPG ? if so it might be worth getting it fixed , if not get it fitted plenty of places doing lpg fitting now for less than £750
Expect 4-4.5 miles for a litre on gas but I only pay 44p per litre and a much extended engine life , mine has now done 300,00+ miles
On your first point mpg for the later transit 2.3 all I can say is that there are always a good selection on ebay needing engine repairs for sale !!!
The later engine is a bit of a dog really and is not a good match for the van, I believe that the MPG was worse then the MK6 as well .
