newbie transit owner. help needed
Postby leeandrews272 » Fri May 26, 2017 10:20 pm
hi all. just got 2.0 td swb semi high roof T280 53 plate transit and as i put stock in back (basically car boot stock). the van makes a knocking noise near the rear (under) of the van and its puzzling me the problem. thanks for reading this ... hoping to find out the problem asap
Sent from my SM-G920F using Tapatalk
leeandrews272
Re: newbie transit owner. help needed
Postby ned » Fri May 26, 2017 10:43 pm
Is it a knocking noise,
All the time while driving,
Only when going over bumps,
When accelerating,
When braking,
Only when cornering left or right,
Have you looked underneath for anything obvious like broken leaf springs/mounts, exhaust knocking against the bottom of the van etc.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby caudy » Fri May 26, 2017 11:37 pm
Check the spare wheel is not loose theres a tightening screw on the inner cill of the r/h/s back door in a hole that sometimes has a bolt in it
if it aint broke....dont fix it
2001 mk6 2.0 Duratorq swb panel van
caudy
Postby bigjohnthomas » Fri May 26, 2017 11:41 pm
This is a common problems
I help you fix 8)
All is needed 4 cans of special brew and 6 lesbian
Hope this help
Allcock umbongo
bigjohnthomas
Postby leeandrews272 » Sat May 27, 2017 12:49 am
nedforceone wrote:Is it a knocking noise,
When accelerating,
When braking,
its mainly when going over bumps. looked under and all looks ok but when the van is unloaded - there is nothing
leeandrews272
Postby leeandrews272 » Sat May 27, 2017 12:51 am
caudy wrote:Check the spare wheel is not loose theres a tightening screw on the inner cill of the r/h/s back door in a hole that sometimes has a bolt in it
will have a look in morning but spare wheel is in over head.
leeandrews272
Postby richgold » Sat May 27, 2017 11:14 am
leeandrews272 wrote:will have a look in morning but spare wheel is in over head.
It could be the spare wheel carrier which due to having no weight in it is knocking when the van is moved.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby leeandrews272 » Sun May 28, 2017 5:01 am
only knock when i have a loaded van. only does it on rough roads as took it on m1 and was fine
leeandrews272
Postby amlav » Sun May 28, 2017 11:22 am
It could be the shock absorbers .... or rear leaf springs lost tension and stopper hits the axle when going over bumps .
amlav
Users browsing this forum: md89
