You may have seen my first post New Van. I'm very pleased with it and now I have replaced the damaged panels and fitted some proper ford mudflaps all round shes looking very tidy. Now despite telling you I'm an ex mechanic and that I spent 10 years working on Transits mostly smileys and MK6's but Mk7's in the last few years, I do have an ABS issue with the van, the light is on all the time along with the red brake warning light,I have put my generic obd scanner on the van and apart from the missfire which I was expecting, no other codes showed, the lights very occasionally go out for a few seconds but soon come back on. Can anyone give me any pointers as the MK6's I used to look after (around 20 of them) none had abs. I do wonder if the cab has been jet washed but no other electrics play up apart from the fuel gauge being a little slow on the up take sometimes. It has not been jet washed under the bonnet so I'm hoping the abs module is ok. Thanks in advance for any help or pointers. Just to confirm it's a 2005 MK6 2.3 petrol.
