Drivers door central locking fault.
Postby Arnie-buxton » Sun May 28, 2017 7:12 am
Morning folks, I have a fault on my 2010 MK7 transit where as the drivers door is not working off the key fob, when pressed all the other doors lock but not the drivers, am i correct in presuming it is likely to be a fault with the actuator or is there another possibility dont really want to strip the door panel down and then find out it was a fuse or something ,,, Cheers Arnie.
Arnie-buxton
Re: Drivers door central locking fault.
Postby ake » Sun May 28, 2017 8:21 am
It's either the actuator, or the wiring to it.
It's probably the actuator
Postby Arnie-buxton » Mon May 29, 2017 9:35 am
Thanks mate, i'll take a look later
Arnie-buxton
Postby Arnie-buxton » Sun Jun 04, 2017 6:32 pm
Still stuck on this one folks .. Wiring seems ok, is there a relay for just the drivers door, if so where is it situated ?, I have a manual and it says that there are 7 relays , Im not sure where to look though , cheers Arnie.
Arnie-buxton
Postby knobby1 » Sun Jun 04, 2017 8:48 pm
Arnie-buxton wrote:Still stuck on this one folks .. Wiring seems ok, is there a relay for just the drivers door, if so where is it situated ?, I have a manual and it says that there are 7 relays , Im not sure where to look though , cheers Arnie.
No relay for just the drivers door...As mentioned...it'll be the actuator itself failed...will need replaced...pretty common problem.
Postby Arnie-buxton » Fri Jun 09, 2017 5:12 am
thanks mate, ill see if i can find one on flea bay
Arnie-buxton
