fuel rail
fuel rail
Postby griffin41 » Sun May 28, 2017 10:51 am
As any one got a clue as to why Ford stopped selling sensor on the common fuel rail separately - there must be a reason other than money (2.2 tdi censor furthest from fuel pump
thanks
that is not my belly - i just need to make that clear and if you find a cure let everyone know it
griffin41
Re: fuel rail
Postby ake » Sun May 28, 2017 3:44 pm
griffin41 wrote:As any one got a clue as to why Ford stopped selling sensor on the common fuel rail separately - there must be a reason other than money (2.2 tdi censor furthest from fuel pump
thanks
I don't think they ever sold it seperately
Re: fuel rail
Postby loot » Sun May 28, 2017 3:47 pm
Ids map here
loot
Re: fuel rail
Postby griffin41 » Mon May 29, 2017 4:39 pm
Thanks for replying - the parts person told me they no longer sell them on there own so that just made me wonder what the reason could be - I have one off eBay but not sure of there quality as the tick over sometime goes lumpy
griffin41
Re: fuel rail
Postby loot » Mon May 29, 2017 5:37 pm
Money probably, the rail itself will probably never fail except by being damaged by the user.
The rail pressure sensor is also quite easy to damage if you look at the thread compared to the main body.
The sensor itself rarely fails tho so i would probably not worry about them until last.
Ids map here
loot
Re: fuel rail
Postby knobby1 » Mon May 29, 2017 9:15 pm
griffin41 wrote:Thanks for replying - the parts person told me they no longer sell them on there own so that just made me wonder what the reason could be - I have one off eBay but not sure of there quality as the tick over sometime goes lumpy
If your tickover is lumpy, it won't be the pressure/temp sensor causing it, as mentioned, they rarely fail....more likely the SCV/PRV...a session on IDS and doing the learns may help.
Re: fuel rail
Postby griffin41 » Mon Jun 05, 2017 2:28 am
thanks for reply's scv and prv are new from ford - had 4 new injectors fitted but one keeps saying injector restricted 3 - what really winds me up is that every now and again it idles and drives lovely and smooth :mrgreen:
griffin41
Re: fuel rail
Postby knobby1 » Mon Jun 05, 2017 4:13 am
griffin41 wrote:thanks for reply's scv and prv are new from ford - had 4 new injectors fitted but one keeps saying injector restricted 3 - what really winds me up is that every now and again it idles and drives lovely and smooth :mrgreen:
Has your PCM been updated to the latest..?? Do you have anti-stall..??
Unless "ALL" the pump and pilot learns are completed successfully, she'll never run properly. If you have a duff injector, you'll most likely never get the learns done properly.
They're terribly finnicky at best.....everything has to be "just so" or they'll have a hissyfit and throw all their toys out of the pram...
Re: fuel rail
Postby griffin41 » Mon Jun 05, 2017 7:36 am
Chears for that info - the van has been to ford for the upgrade but I added the parts the day after - I'll givery it to ford and see what they say
griffin41
Re: fuel rail
Postby knobby1 » Mon Jun 05, 2017 8:40 pm
griffin41 wrote:Chears for that info - the van has been to ford for the upgrade but I added the parts the day after - I'll givery it to ford and see what they say
So you've had a PCM update done, then the day after fitted a new SCV & PRV and have "not" had the learns done..?? :?
If so, it will not run properly until all the learns are completed successfully.
Re: fuel rail
Postby griffin41 » Mon Jun 05, 2017 10:50 pm
Had the learns done today but it's still seems to miss lol
griffin41
