MK7 2008 T350 140 RWD 2.4 TDCI LWB high Roof
What sets dtc codes for turbo overboost and underboost?
Could it be the fuel pump pressure control valve again, (last replaced 100,00km ago) or perhaps the common rail pressure relief valve?
Or is there another likely culprit?
HISTORY:
I had a code for faulty egr and power kept dropping until a re-start to reset the computer. So I had a faulty egr valve which I replaced. The error code for the egr fault is gone but now I have turbo under boost and overboost codes set.
While I was installing the replacement egr valve I installed an egr restrictor plate with a 6mm centre hole (to let some gas through to fool the computer). I do not think this is the fault. I think the fault is the fuel pump pressure control valve again, (last replaced 100,000km ago by Ford) or perhaps the common rail pressure relief valve?
Any constructive ideas?
Will
