v8dave wrote:The item you marked in red is the exhaust gas cooler for the exhaust gas recirculation system.
The item you marked in blue is one of the water connections to the cooler.
If exhaust gases are coming out of the blue pipe then your cooler has failed and needs replacing.
The original pipe from the stub marked in blue would have gone to the heater.
There would originally have been a second water connection in to the egr cooler from the oil filter housing and oil cooler, it is behind the egr valve in the image you've posted.
Stumped wrote:v8dave wrote:The item you marked in red is the exhaust gas cooler for the exhaust gas recirculation system.
Ah cheers Dave for the swift response. Looks like someone before me has bodged it for some reason and just left it. I will get onto researching all the info you've given me. Thanks again. Marcus
v8dave wrote:Assuming the picture you used is representative and this is a mk7 then the egr has to be disabled in the engine control software.
Once that is done you could remove the hardware.
However the blanking plates on <a href="http://ebay.co.uk" class="skimwords-link" target="_blank" data-skimwords-id="874161" data-skimlinks-editor="0" data-skimwords-word="ebay" data-group-id="0" data-skim-creative="300001" data-skim-product="874161" title="" occurrence="1" data-skim-node-id="194:Howevertheblankingpl_2" style="">ebay</a><span style="position: absolute;"></span><span style="position: absolute;"></span> seem to be designed to fit at the egr valve, you would need to blank the connection between the exhaust manifold and the cooler with your own design of plate.
motorman116 wrote:v8dave wrote:Assuming the picture you used is representative and this is a mk7 then the egr has to be disabled in the engine control software.
That looks like the 3.2 200ps 5 pot lump
motorman116 wrote:The Egr cooler pipe splits internally and leaks exhaust gases into the cooling system / pressurizes the cooling system, this is why people bypass them.....
knobby1 wrote:The EGR cooler does run across the back of the engine and is indeed a pig to get at....there's two bolts at either end of the cooler and you'll need to get at them from either side or underneath. There's also a bracket holding the EGR cooler assy to the back of the cyl head...a real ball-ache to get at.
If trying to get at it from underneath, you may need to remove the starter to get access to the passenger side bolts. If they're badly corroded, I don't like your chances without removing the gearbox to get decent access. Good luck...you're gunna need it.
v8dave wrote:Fit the blanking plate to the egr or you will have a leak on the inlet system.
You'll also need to get the egr deleted in the engine software, otherwise you'll have the engine warning light on.
