KevofCov wrote:2010 3.5t RWD 2.4 LWB 240,000 miles
As me dad always says – some days the Pigeon, somedays the Statue.
Today I am a lucky lucky Pigeon with air con.
nedforceone wrote:How much does a garage charge for a re-gas 30 - 40 sovs?
Altransit wrote:nedforceone wrote:How much does a garage charge for a re-gas 30 - 40 sovs?
I just had a local guy come to my house, check the system for leaks, de-gas, clean, lube, and re-gas, and all for £35
Beats hanging around whilst the garage do it
KevofCov wrote:Cheers
Not on drugs, just like pigeons..
Will see if I can get a mobile guy...
bigjohnthomas wrote:Machines ? Am I correct in saying , fill it up with nitrogen then spray washing up liquid round the bits you can see to check for leaks. Then, Vac it out for a bit then a splash of oil in then,, weigh your gas bottle put it on some scales look how much weight of gas should be in it. Turn gas on ,gas runs out before its full , get another bottle of gas out, can't remember how much has already gone in, so gives it a good "drink " and say all good thats sixty quid smallcock
Altransit wrote:bigjohnthomas wrote:Machines ? Am I correct in saying , fill it up with nitrogen then spray washing up liquid round the bits you can see to check for leaks. Then, Vac it out for a bit then a splash of oil in then,, weigh your gas bottle put it on some scales look how much weight of gas should be in it. Turn gas on ,gas runs out before its full , get another bottle of gas out, can't remember how much has already gone in, so gives it a good "drink " and say all good thats sixty quid smallcock
That may be the case over in Lincolnshire where you have no electricity, but here in civilisation they use proper aircon machines (with dials and knobs, and everything!) that do the lot in one handy sized container
But they do need mains electricity
