Blue key programming
Re: Blue key programming
Postby birdie » Thu Jun 22, 2017 8:48 am
So can I run forscan on a different device, I have a Delphi diagnostic interface
mk7 T350 FWD towing van
birdie
Postby davyjcb » Thu Jun 22, 2017 11:55 am
That adaptor looks identical to my own so should be ok,I like the usb units better than bluetooth , the speed is better and the connection more reliable the bluetooth ones have been known to freeze
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby Rob T » Thu Jun 22, 2017 6:18 pm
davyjcb wrote:That adaptor looks identical to my own so should be ok,I like the usb units better than bluetooth , the speed is better and the connection more reliable the bluetooth ones have been known to freeze
Thanks, me too I feel like you get a better connection on wired USB to bluetooth or wifi. I might have to code a pump on a Focus diesel next week so this could pay for itself quite quickly!
Rob T
Postby Karst » Sat May 26, 2018 9:17 pm
Hi Rob T and Folks,
I've been going through this process with Forescan and a new key.
I got a second hand laptop on eBay for £200, and bought a lead from Amazon. Got a lot on, so haven't been able to complete the whole thing yet. But it seems like something in my van (ex Royal Mail) is blocking access by Forescan.
I was quoted £260 by Ford for a duplicate key cut and programmed! £108 per hour labour charge! So I bought a new one for £60 from eBay, got it cut for £6, and am eagerly awaiting programming it myself.
Ford Transit Mk 7 Panel van, ex-posty's, 57 reg, 2007. Duratorq TDCI 2.2 (85PS)
Karst
Postby riauba » Tue Jul 10, 2018 9:49 pm
Am i correct, that i can use second hand fob to program to work on my van? i got ids, but i was able to use new virgin key only.
riauba
Postby davyjcb » Wed Jul 11, 2018 4:55 pm
Yes you can reprog a second hand key with forscan,just remember to fasten it to your existing key with tape an charge it it will take the transponder coding OK but if the central locking battery is dead it won't take the code for the buttons
davyjcb
Postby riauba » Wed Jul 11, 2018 5:57 pm
Great, just programmed second hand blue key with IDS, always was buying new virgin fobs on ebay, as someone said that ids accepts only new keys.
riauba
Postby davyjcb » Wed Jul 11, 2018 6:33 pm
The key is "stupid" the van isn't coded to the key,when you programme a key the pats flashes the transponder a new identity I had to get a van going and used the spare for my van it worked grand the only downside was the fob still opened my van although it wouldn't start it
davyjcb
Postby davyjcb » Wed Jul 11, 2018 6:37 pm
BTW when I discovered the fob still opened my van I deleted all the keys and just had my main and new spare ,always a good idea to do away with any unaccounted keys from the vehicle your working on
davyjcb
Postby Karst » Thu Jul 12, 2018 6:59 pm
davyjcb wrote:Yes you can reprog a second hand key with forscan,just remember to fasten it to your existing key with tape an charge it it will take the transponder coding OK but if the central locking battery is dead it won't take the code for the buttons
Hey Davyjcb, I tried something today.
I have a new blue key which is as yet unprogrammed. I got it cut for £6 on eBay.
I started my van with the old programmed key, flipped out the blue part with a small screwdriver, and popped the new blue part in to charge up the battery. The van kept running. No probs :mrgreen:
Karst
Postby Altransit » Thu Jul 12, 2018 11:20 pm
Karst wrote: The van kept running. No probs :mrgreen:
It will do; the immobiliser is inoperative once the engine is running, and will only reset when you stop the engine and take out the key.
It won't re-start with the non-progragrammed key, you'll just get the immo light flashing fast :)
Postby davyjcb » Fri Jul 13, 2018 2:26 pm
Altransit is 100% correct it will only look for transponder when turned on from pos 0 once it's started it doesn't care
davyjcb
Postby riauba » Fri Jul 13, 2018 3:11 pm
funny thing is that i used my own key from another own van, and now when locking unlocking, both vans locks unlocks on the same key, at the same time when parked close. just it doesn't start old one.
riauba
Postby davyjcb » Sat Jul 14, 2018 4:10 pm
The remote entry loads the info from the fob to the locking module cos the fobs have fixed signal outputs .The transponder is reversed it gets set by ids and the pats so that's why you can open both vans but not start one firm I do work for has a fob that opens every mk 7 in its fleet
davyjcb
