The van ran fine for 5-10 minutes, then starts cutting out. Using the computer it throws out error code P0335. I manage to locate the sensor and replace it but now the engine does not start and gives out error P1665 (did not appear beforehand).
I've checked the pump EDC and the fuel pump relay in the fuse box and pin 7 in the EDC has no voltage on ignition/startup. From another post it says that pin 7 is the main power feed to the pump, so my guess is that there should be a power running through it? Pin 4 shows 12V, just thought it seemed too high, I am not sure if the other pins are fine as I don't know what they should be reading.
I've read upon many other similar problems for the last few weeks and nothing seems to work. Looking for help at this stage as I'm lost on what to do.
