Mk7 high level brake light
Postby Andrewt » Tue Jun 20, 2017 6:30 pm
The high level brake light on my van wasn't working so investigated and found the plug to be all corroded so decided to get one and just do away with the plug and hard wire it so took my light out removed the gibbons and replaced the lens until I found another unit but went to fit the unit and now my wiring has disappeared I'm assuming is fallen down the door any ideas how to get it back up?? Iv tried a thin wire curled over like a hook but no joy also which side of the door does it run down?left side between the skins or right side between the skins??
Andrewt
Re: Mk7 high level brake light
Postby knobby1 » Tue Jun 20, 2017 10:53 pm
I believe the Hi level brake lamp wiring lives in the right side of the left rear door...see here:
http://www.catcar.info/ford/?lang=en&l= ... NisxMzU%3D
Postby dirtydog » Tue Jun 20, 2017 11:23 pm
The wires for mine fell down into the lower part of the door so,I had to take the panel off. I used a bit of twin and earth cable to hook it and feed it back up the door
dirtydog
Postby Andrewt » Tue Jun 20, 2017 11:44 pm
Brilliant thanks my rear doors have wood panels I took the top one off but couldn't get entry between the skins so I assume if I remove the bottom wood panel I can get access between the skins to feed a cable down and hook up the lighting wires?
Andrewt
Postby knobby1 » Wed Jun 21, 2017 12:01 am
Andrewt wrote:Brilliant thanks my rear doors have wood panels I took the top one off but couldn't get entry between the skins so I assume if I remove the bottom wood panel I can get access between the skins to feed a cable down and hook up the lighting wires?
Aye....that'll be the only way I think....unless you have ridiculously long & skinny arms... :wink: :mrgreen:
Postby Dreadonaught » Thu Nov 23, 2017 3:28 pm
Hi All,
Is there a recommended high level kit for the Mk6 high roof?
Or a roof mounted one as I have vents sticking up anyway?
Dreadonaught
Postby knobby1 » Thu Nov 23, 2017 7:32 pm
Dreadonaught wrote:Hi All,
Get one for a Mk7 and wire it to the brake lights. Wreckers might be a good place to start looking. Some auto parts places and fleabay sell universal jobbies which sits/sticks on the rear door glass....something like this one:
https://www.ebay.com.au/itm/84650BL-Nar ... Swr1tZ~n7X
Postby Dreadonaught » Tue Nov 28, 2017 1:12 pm
Thank You
Dreadonaught
