MK7 2.2 TDCI Transit blowing out blue/white smoke.
Postby Vittese » Tue Jun 20, 2017 8:47 pm
Hi guys,this is my first post on this forum, i have a problem with my Transit van,that i an hoping you good people may be able to help me with. The van is a 2006 MK7 2.2 tdci Transit, that broke down in a cloud of smoke a few days ago. The van was running fine but started to lose power, the engine started to shake with clouds of smoke coming out of the exhaust. The recovery man did a diagnostic on the van and advised me that number 1 and number 2 injectors were faulty. I replaced both injectors, got them re-coded but the van was exactly the same as before, engine still shaking and blowing clouds of smoke from the exhaust. I bit the bullet and got the van towed to a Ford main dealer, they rang me to say that there was oil dripping from the exhaust and advised me that they were 90% sure that the van had a cracked piston, as this is common on these vans, so there wasn't any point at that stage of doing any further diagnostic checks. I started to strip the engine today in order to remove the cylinder head, but when i removed the inlet manifold i noticed all of the inlet ports in the head were black with oil. I am only a DIY mechanic, but oil in every inlet port doesn't seem like a cracked piston to me. Would a blown turbo, or a fault EGR valve cause these problems?
Any advise would be really appreciated. Thank you, Martyn.
Vittese
Re: MK7 2.2 TDCI Transit blowing out blue/white smoke.
Postby pwhooftman » Tue Jun 20, 2017 9:12 pm
My guess is the increased crankcase pressure blows oil through the crankcase breather into the inlet. But i admit i'm not familiar with the crankcase breather setup on these types of engines.
Ford Transit Mk6 (2001) 2.4 Tddi 120 PS RWD twin wheel motorhome, tickled by Vantuner :D
pwhooftman
Postby Vittese » Tue Jun 20, 2017 9:47 pm
Hi, thanks for your reply, much appreciated.
Vittese
Postby Altransit » Tue Jun 20, 2017 10:22 pm
I'm no expert either, but from what I've read on here, a blown turbo normally causes the engine to run away, not lose power, but on the other hand, these engines can be prone to cracking pistons :(
Surely a simple compression check would have confirmed this one way or another :?: :?
Postby ned » Tue Jun 20, 2017 10:24 pm
What if the chain has jumped, would it cause the symptoms your getting?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby knobby1 » Tue Jun 20, 2017 11:55 pm
I'm guessing a blown/cracked piston...(probably #1 or #2 cylinder).. Not what you want to hear but your symptoms point to it..! :(
Postby Vittese » Wed Jun 21, 2017 12:04 am
Hi guys, thanks for your replies. Unfortunately i cant do a compression test due to the glow plugs wont come out.
Vittese
Postby knobby1 » Wed Jun 21, 2017 12:19 am
Vittese wrote:Hi guys, thanks for your replies. Unfortunately i cant do a compression test due to the glow plugs wont come out.
A compression test can also be done through the injector holes...but uses one of the older "push 'n hold" type gauges as there's no thread to screw into.
Postby Vittese » Wed Jun 21, 2017 3:36 pm
Hi, thanks for the info, i will try to do a compression test through the injector holes.
Vittese
Postby Vittese » Mon Jun 26, 2017 10:58 pm
Hi guys, thanks for all of the advise. I removed the cylinder head over the weekend, the problem is a cracked/holed piston on number 2 cylinder.
Vittese
Postby knobby1 » Tue Jun 27, 2017 3:53 am
Vittese wrote:Hi guys, thanks for all of the advise. I removed the cylinder head over the weekend, the problem is a cracked/holed piston on number 2 cylinder.
Guessed as much...Sorry for your loss.. :(
