weird abs fault
weird abs fault
Postby maccavvy » Wed Jun 21, 2017 10:59 am
Hi guys got abs light on..
had it diagnosed as o/s sensor .
ordered a new one from tpuk
fitted still a fault. found a break in the vans wiring just before the plug
which I cant seem to find anywhere. so cut it off and soldered a different waterproof plug on.
light still on. not had it diagnosed as yet as its a cost I can do without
ive checked the wiring for chafing . up to the tank theres nothing.
is there a way I can test it with a ohm testmeter or something?
is there something else I should be looking for ?
Mk8 310 trend FWD and a 5.7 ls1 monaro RWD
maccavvy
Re: weird abs fault
Postby maccavvy » Wed Jun 21, 2017 3:08 pm
small update.. checked continuity of all cables from axle to connector at front.
no earth faults
no breaks in cable.
At a loss now
maccavvy
Re: weird abs fault
Postby ake » Wed Jun 21, 2017 6:20 pm
Get it on diagnostic again and see if it's still the same fault
You didn't cross the wires over did you? They may be polarity sensitive
Re: weird abs fault
Postby bambi mk 1 » Wed Jun 21, 2017 7:59 pm
Have you road tested the van after you did the repair :?: You need to do 20 mph approx. to put the light out without a scanner :wink:
bambi mk 1
Re: weird abs fault
Postby maccavvy » Wed Jun 21, 2017 8:06 pm
yes been for a drive back to garage and still shows both rear sensors
No wires were crossed.. just disconnected and tested
maccavvy
Re: weird abs fault
Postby maccavvy » Wed Jun 21, 2017 9:11 pm
can they be read live... and what do I need ??
do they have a resistance I can easily check
maccavvy
Re: weird abs fault
Postby loot » Wed Jun 21, 2017 10:32 pm
My lwb all 4 sensors connectors read roughly 750 ohms.:-)
Ids map here
loot
Re: weird abs fault
Postby maccavvy » Wed Jun 21, 2017 11:16 pm
cheers gives me something to aim for.
does it change as you rotate ???
maccavvy
Re: weird abs fault
Postby loot » Wed Jun 21, 2017 11:45 pm
Yes :-)
Ids map here
loot
Re: weird abs fault
Postby maccavvy » Thu Jun 22, 2017 9:48 pm
update time
set off to work this morn.. no lights.. approx. 2 miles from home on it pops.
2pm set off from job no lights on again ..about 4 miles later .. on it pops again.
I'm thinking the rear harness is at fault.. as since I messed with it I now have something changed
maccavvy
Re: weird abs fault
Postby loot » Thu Jun 22, 2017 11:44 pm
Wiring fault will have the light on straight away on key on diagnostic.
Sensor fault ie calibration or ring problem brings the light on while driving.
I think you should recalibrate the longitudinal and steering sensors, physically check the reluctor rings for dirt/breaks, and check and make sure that the tyres are the same size and pressure and that the steering tracking is good.
Ids map here
loot
Re: weird abs fault
Postby maccavvy » Fri Jun 23, 2017 7:37 am
I'm thinking wiring as the light used to be on all the time.. since I messed with wiring (uncovered some of the loom to check for breaks /rubbing) its now intermittent.
Are the rear sensor ring easily visible to clean up ?? or is it discs off ??
tyres are fine and tracking was done 3 weeks ago as it was scrubbing the fronts
How do I recalibrate the sensors?
hopefully I get an early finish and look into the other things too
maccavvy
Re: weird abs fault
Postby loot » Fri Jun 23, 2017 8:16 am
Calibrations need ids or similar diagnostics, wheels straight ahead and parked on level ground, 5 minute procedure but well worth doing as it'll save you a lot of other work trying to find the problem.
Intermittent coherence problems should bring up a historic fault as wiring as breaks will cause open circuit rather than signal out of range.
Intermittent warning lamp should be diagnosed if possible but you need diagnostics that can read all the abs info :-)
Ids map here
loot
Re: weird abs fault
Postby godderidge » Fri Jun 23, 2017 1:21 pm
Check the wiring loom close to abs pump at the point that the earth wire to the starter motor is and see if the two have chaffed together
godderidge
Re: weird abs fault
Postby maccavvy » Fri Jun 23, 2017 10:35 pm
ill try to find someone with ids close by then ..
ill also check the wiring you speak of too
maccavvy
