Hi, Long time no post
Recently I had a 150w solar panel & mppt controller fitted to my ex network rail clarks conversion T350.
The installer had issues working out where to wire the charge output. As an interim solution, he wired it to the feed for the rear interior lights (on the overhead electrical panel).
Both the starter and leisure batteries are wired in parallel on my van, and because the solar output goes to all batteries, the 'weakest' (starter) battery dictates the cut-off for charging, meaning that the AGM leisure batteries never really get charged beyond 80% off the panel. They read 12.7 at rest - which is 100% charged for the lead acid starter!
I was wondering if anyone else had encountered a similar problem, and knew where to connect the panel to bypass (if possible!) the starter battery, so it no longer dictates the overall voltage? Or is it possible to fit some sort of isolating switch to take the starter battery out of the habitation circuit altogether when we're parked up & camping?
