Hello all
I'm new to the world of transits and this forum
So hello to u all
Can anybody help me with the above issue with the trip resetting itself for no real reason or set pattern
Poss ipk soft ware update or tsb??
Many thanks
Paul
davyjcb wrote:the 1st battery does all the donkey work and the 2nd only latches in when key on and engine running
v8dave wrote:davyjcb wrote:the 1st battery does all the donkey work and the 2nd only latches in when key on and engine running
On the factory twin battery setup the pair are connected when the engine is running.
One is disconnected shortly after the engine is turned off to preserve it for the next restart, it is latched in when you turn the ignition on again.
ake wrote:Actually, they are connected at key on, but disconnect again if engine isn't started in 120seconds!
They stay connected with engine running until either key off, or you stall it
v8dave wrote:ake wrote:Actually, they are connected at key on, but disconnect again if engine isn't started in 120seconds!
Ake,
Don't the pair stay connected for 120 seconds when you stall it ?
ake wrote:No, drops out almost straight away, I've got a 350 parked round the back, so I've just been out and stalled it
