Hi guys I'm gonna recut my injector seats clean the surface up with a cheap cutting set I bought but not sure which size I use, is it the 17x17mm cutting piece required?
Also what do you do about the waste cut off is it ok to allow it go into the cylinders or try to use a magnet or something to get it out?
