Mk7 2.2 85ps ticking/knocking
Re: Mk7 2.2 85ps ticking/knocking
Postby knobby1 » Sat Jul 22, 2017 7:18 am
tjm07 wrote:https://www.youtube.com/watch?v=K7LvKKB3hug&sns=em. Please listen to vid and share your views on cause of noise
Sounds like a duff hydraulic lifter/tappet to me, or possibly a collapsed roller...have you checked them all thoroughly..!??
Postby tjm07 » Sat Jul 22, 2017 7:40 am
I have, but will check again. I had it ticking over for a good 40mins yesterday, and noise didn't occur until I revved the engine so to me it's temp or pressure related? Rocker cover is also blowing so going to have to order a seat cutter.
2008 Mk7 Swb transit crew bus 85ps
2002 BMW 320d e46 204k and counting SCRAPPED
2005 Vauxhall astra sri SOLD
2005 BMW 320i m sport
2006 Vauxhall Astra 1.4 affectionately nicknamed s#*tbox
tjm07
Postby Altransit » Sat Jul 22, 2017 8:44 am
tjm07 wrote: Rocker cover is also blowing so going to have to order a seat cutter.
Do you mean the injector seats :?:
If they're blowing, that will surely be the source of your ticking/tapping :? That's how mine were when the clamp bolt wasn't tight :(
Postby tjm07 » Sat Jul 22, 2017 6:44 pm
Thank for replies. Knobby, I will inspect rockers thoroughly, is there a way of testing the hydraulic lifters? Altransit, appreciate your advice and it is re-assuring, did you listen to my vid? my injectors are tight, and I did clean the faces with some emery cloth, but they appear to still be passing so I will order a seat cutter and new washers and see where that takes me, thanks again
tjm07
Postby tjm07 » Wed Aug 09, 2017 7:21 pm
Update, everything is taking an age, had to wait over a week for eBay's finest seat cutter to arrive, new sealing washers and bolts ordered, washers arrived still waiting for bolts (over a week) knew I should have gone to fords but was concerned I wouldn't get the opportunity to get there so ordered off eBay genuine new bolts over a week ago. Is there a way I would know if the injectors were bad, I have previously done a leak off test which came back equal/balanced, I have also successfully completed injector and pump learns at various stages off repair using f-super. Thoughts/suggestions welcome
tjm07
Postby karl » Wed Aug 09, 2017 7:39 pm
trying to get me head around this so you done a engine rebuild but pistons gone again ?
karl
Tranny Lover!!!
Postby tjm07 » Wed Aug 09, 2017 7:46 pm
No long story mainly because of my inexperience, pistons now fine, engine runs really nicely, just getting a ticking/knocking noise now once warmed up or revved hard. I believe it is injector seals as the only symptom at the moment is pressure within the rocker cover, so just waiting for new clamping bolts to arrive so they can be fitted with new washers, I ask about the injectors as I was sure I read or understood it as the injector learn would fail if there was an issue with an injector?
tjm07
Postby tjm07 » Fri Aug 11, 2017 5:57 pm
tjm07
Postby tjm07 » Fri Aug 11, 2017 5:58 pm
tjm07
Postby tjm07 » Fri Aug 11, 2017 6:00 pm
Please watch/listen to today's vids, new injector seats cut, new injector seals and new bolts fitted, still getting pressure in rocker cover and still get an intermittent ticking, which is worse and more frequent when revved. Help please
tjm07
Postby tjm07 » Sun Aug 13, 2017 9:06 am
Any suggestions on my next move?
tjm07
Postby BHM » Sun Aug 13, 2017 9:50 am
Got a compressor ? if so...
A leak down test for starters
BHM
BHM
Postby tjm07 » Sun Aug 13, 2017 9:55 am
Yes have a compressor. A leak down test?
tjm07
Postby Thequeenscheese » Sun Aug 13, 2017 10:07 am
Not read all your thread but and I'm prob wrong (just going off you saying its during revving) alternator bearing?
http://www.nissan-navara.net/17-technic ... ick-6.html Or this thread could be similar, this was my old truck and I was the one that posted the answer in the thread after I'd bought the truck..
2.2 tdci T280
Thequeenscheese
Postby tjm07 » Sun Aug 13, 2017 10:14 am
Thanks for your reply, definitely not alternator bearing, have had van running with and without belt on and issue is always present, thanks again. - BHM- have googled leak down test, brilliant idea, do I need the correct attachment for the compressor? I am a maintenance engineer, so my initial idea is to knock up an injector shaped fitting of the lathe to fit in place of injector to allow air connection?? What pressure would be recommended/safe?
tjm07
