help a newbie out please
Postby tompe » Sun Jun 25, 2017 8:44 pm
hi all I really need help before I go mad .I've a mk7 transit front wheel drive transit 56 plate that wobbles betweenr0mph and 50mph I've changed passenger side driveshaft and wishbone but still the same also had wheels n tyres check and balanced.i looked at loads of posts thathas simler problems but carnt see a fix anywhere please help a novice
tompe
Re: help a newbie out please
Postby Airthies » Mon Jun 26, 2017 8:35 am
Recheck front tyres for bulges on the tred. Or swap wheels front to back and see if problem persists or changes.
A bulge will give a wobble at low speeds.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby tompe » Fri Jun 30, 2017 4:30 pm
I've already done the tyres losing the will to live with it
I've seen loads of posts with the problem bit no one says wot fixed it
tompe
Postby Airthies » Fri Jun 30, 2017 11:29 pm
Have you swapped wheels front to back?
Has it changed anything?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Sat Jul 01, 2017 3:05 am
Have you checked the hub nuts on both sides are tight, wheel nuts tight?
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Users browsing this forum: 2ndhandpete, Google [Bot], Google Adsense [Bot]
