karl wrote:no no no no no you need to remove the cross member
karl wrote:no you have to remove the cross member ...................... full stop
bambi mk 1 wrote:karl wrote:no no no no no you need to remove the cross member
Oh no you don't I have done it many times and so has Loot Thread on here somewhere.Loooooooot where are you when we need you
Airthies wrote:If the mk6 is the same as mk7 then it can be done in place! I've done it drop it, turn it, take off oil pick-up & slide it out (That's the condensed version)
loot wrote:Screwdriver?
bambi mk 1 wrote:loot wrote:Screwdriver?
Yip tap the scraper between the sump and the block ,wont damage the sump
You would need some lungs for that with no compressorloot wrote:bambi mk 1 wrote:loot wrote:Screwdriver?
Agreed, i probably only had a screwdriver handy tho i guess, it's probably lucky that i did, imagine if i only had this to hand.
