mk7 transit door seal
Postby finnon » Wed Jun 28, 2017 8:11 pm
got a problem of water getting past the upper seal on the drivers door. the seal thats attached to the van body.
its misshapen so when the door is closed the seal points downover and when it rains water leaks past it. are these available online? or are they a ford only part? or are they easily removed from a scrap van?
cheers
present van is a 55 reg t280 85ps lwb semi high
finnon
Re: mk7 transit door seal
Postby Airthies » Wed Jun 28, 2017 8:47 pm
finnon wrote:got a problem of water getting past the upper seal on the drivers door. the seal thats attached to the van body.
cheers
If
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby knobby1 » Wed Jun 28, 2017 9:25 pm
Airthies wrote: If
WTF..!!?? :? :?: :mrgreen:
Postby Punto443 » Wed Jun 28, 2017 9:51 pm
Easy to remove, they're just pressed on.
I'd try the breakers yard as I'd imagine they'll be expensive from ford.
Mine lets a bit of rain in too, between 90 & 100mph
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Punto443 » Wed Jun 28, 2017 9:53 pm
Airthies wrote: If
You like a lot of chocolate on your biscuit? Join our club :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby finnon » Wed Jun 28, 2017 10:00 pm
ok lads thanks.
ill see if the breakers in darkest sunderland have any in. or the one in gateshead. unless anyone on here has a breaker?
finnon
Postby Punto443 » Wed Jun 28, 2017 10:02 pm
I have a breaker :D
But it's only one for chipping plaster off a wall :lol: :lol:
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby finnon » Thu Jun 29, 2017 12:12 am
a van that they want to break for parts not a power tool haha
i deffo need to be more explicit in what i want like :mrgreen:
finnon
Postby motorman116 » Thu Jun 29, 2017 7:37 am
Punto443 wrote:Easy to remove, they're just pressed on.
Unless its a high top as they have a weather strip glued to the upper and down the window pillar (A-pillar)
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby andz327 » Thu Jun 29, 2017 7:19 pm
knobby1 wrote:
Airthies wrote: If
If.....
andZ3 Sony Z3
andz327
Postby Airthies » Thu Jun 29, 2017 7:29 pm
andz327 wrote:
knobby1 wrote:
Airthies wrote: If
If.....
andZ3 Sony Z3
Erm.......
V86+patch
V86.04
X-Prog
C81
Airthies
Postby finnon » Thu Jun 29, 2017 8:02 pm
aye its a high roof van like. what happens is theres a bit of a dip in the van roof. it fills with water when its parked in rain. then when it moves forward all the rain falls off the roof and runs down the front and sides. the door seal thing is flipped the wrong way and kinda stuck. and the water falls through and splashes everywhere :oops: :oops:
finnon
Postby andz327 » Thu Jun 29, 2017 8:11 pm
Like
andZ3 Sony Z3
andz327
Postby oldarry » Fri Jun 30, 2017 12:27 pm
I've got a variation of this problem, water appears under the plastic step liner on the driver's side, med roof Mk7. I've changed the top seal - top of door and slope alongside windscreen - no difference. The rim seal clipped all the way round the door frame looks fine. I've checked under the rim seal a few times after rain and it looks, unbelievably, like the water is coming through the seam about half way up the wheel arch. How it does that without driving along in the rain, f knows.
oldarry
Postby motorman116 » Fri Jun 30, 2017 6:52 pm
oldarry wrote:I've got a variation of this problem, water appears under the plastic step liner on the driver's side, med roof Mk7. I've changed the top seal - top of door and slope alongside windscreen - no difference. The rim seal clipped all the way round the door frame looks fine. I've checked under the rim seal a few times after rain and it looks, unbelievably, like the water is coming through the seam about half way up the wheel arch. How it does that without driving along in the rain, f knows.
Check the roof gutter, as if it has had a roof rack fitted, this can cause the guttering to split this leak water in down the inner wheel arch..
motorman116
