nedforceone wrote:Its in the cylinder head.
nedforceone wrote:It bolts in at the inlet side I think, near the glow plugs (but I could be wrong) the temp gauge reads the cylinder head temperature not the water temperature.
nedforceone wrote:No the temperature gauge on near the speedo reads the cylinder head temperature, there is no water temperature gauge.
jamiediscos wrote:hi there, I had the exact same problem with my 2002 2.4 di 15 seater minibus. turned out to be the water pump impeller. changed water pump and it's now right as rain again. hope this helps.
Users browsing this forum: Dave Poulter, Google [Bot], Google Adsense [Bot]
