2 Completely failed remote fobs?
Postby Karst » Sat Jul 01, 2017 10:18 pm
Hi My very valued and really helpful Transit folks,
I have had a couple of basically reliable remote fobs for my 2000 Mk 6 Transit for a few years.
A while back they started failing intermittently, and a kind fellow on here said all they needed was new batteries. Indeed, that was all they needed!
(I also tried changing the module just before that, but that didn't work)
Now though, both my fobs have suddenly failed, even though I've tried several different brand new batteries in them and done the standard reprogramming method several times. The reprogramming goes through all the motions just fine, door locks cycling twice, but then the remote buttons on the fob do absolutely nothing.
I have had a search for this problem on the forum, but yes, I could not find this exact problem.
I'm sure it's something really simple?
Please help? :?
Karsty.
Ford Transit Mk 7 Panel van, ex-posty's, 57 reg, 2007. Duratorq TDCI 2.2 (85PS)
Karst
Re: 2 Completely failed remote fobs?
Postby robbie.cee » Sun Jul 02, 2017 7:05 pm
Have you checked fuses etc?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Karst » Mon Jul 03, 2017 5:52 pm
Hi Robbie,
Thanks for that.
The whole locking and alarm system still works normally through manually using the key in the driver's door, but I checked the fuse under the steering column anyway (nearly bust a gut getting to it and putting it back!) Nothing wrong with it!
Karst.
Karst
Postby ake » Mon Jul 03, 2017 8:18 pm
I'd be suspecting the receiver module if everything else appears ok
Postby Karst » Tue Jul 04, 2017 11:37 am
Karst
Postby Altransit » Tue Jul 04, 2017 1:54 pm
Karst wrote:Hi Robbie,
Thanks for that.
Karst.
:? There should be two fuses under there, did you check both of them :?:
Postby ake » Wed Jul 05, 2017 7:12 am
Postby Karst » Wed Jul 05, 2017 9:32 pm
Thanks Ake, I think I'm gonna have to try that.
Hey Altransit, I had another look and found 3 fuses, 1 x 15A and 2 x 7.5A here - https://goo.gl/photos/dp9Xadqnwa34WPn98. All 3 were fine. Are there more?
Karst.
Karst
Postby Karst » Thu Jul 06, 2017 10:01 pm
I've just ordered the Central Locking & Alarm System Module.
Karst
Postby Karst » Sat Jul 22, 2017 12:04 pm
I got the module several days ago, but still haven't fitted it, but hopefully will get it in yesterday.
Honestly, I've been using the key to lock/unlock it, and in many ways it's easier than pressing the fob buttons 10 times before they work and always having to walk round to the right place at the van so the signal gets through.
Did you know if you hold the remote fob at your head it amplifies the signal? Have you ever tried it? I tried it through 2 brick house walls. Held normally - no effect. Held against the head - it worked consistently. Do you think it would cause any brain damage?? Otherwise I could use that method all the time and never have any remote fob problems.
Karst.
Karst
Postby wronghole » Sat Jul 22, 2017 1:15 pm
Karst wrote:I got the module several days ago, but still haven't fitted it, but hopefully will get it in yesterday.
Karst.
Jeremy clarkson from top gear said it worked, and he used to do it, he lost his job. Make your own assumption on that one. :lol:
wronghole
Postby Karst » Sat Jul 22, 2017 10:41 pm
It is pretty freaky and amazing though, I saw him demonstrate it (crazy freaky smiley completely mind blown)
Karst
Postby ned » Sat Jul 22, 2017 10:50 pm
Karst.
And now he earns a lot more money as well, N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Karst » Sat Jul 22, 2017 11:08 pm
Maybe it actually improves your brain? I think it's worth a try.
Karst
