Hello everyone. holland calling.
first, my apologies for my use of "simplfied english" as the term goes. i spent way too long in america.
i come to you as the forums in holland for the transit is basically non-existant and even then i am being generous.
more ontopic:
i bought a 2003 mk6, 125bhp TDCI.
problem is that the van has the shakes between 40 and 65, and not "bad balance" shakes, but "van is going to explode" shakes. at speed it is not so bad but when accelerating it really feels like the van is trying to dissasemble itself.
from my readings i kinda figures it is a driveshaft issue and i hope you guys can fill in some blanks for me.
is this issue really a driveshaft (worn joint) issue or is it that way too expensive bearing on the right side shaft?
wich side or what is the actual cause and solution and what is built so craptaculair that causes such amazing issues?
also: if driveshafts needs replacing: what side and what is it with the teeth? i read about a lot of confusion about the amount of teeth the shafts have. can someone elaborate and tell me what type i have so i don't order the wrong parts?
