RayTrans wrote:Lads is this a good price as I bought a Mk6 2.4 Rwd Genuine Ford Timing Chain, Genuine Ford Tensioner, and Guides for £355 pounds
APH wrote:
have never changed sprockets, sprocket bolts, or crank pulley bolts, gaskets may not be essential although they are meant to be one use as metal compression type, I have go away with re using once or twice, but had leaks on some vans, I would however always do the o-ring as have always leaked one if I ever tried to re use.
Andy
Andy
Sprocket bolts didn't feel extremely tight when I torqued mine so I agree they should be fine to reuse. Crank pulley bolts however, I think mine were 70NM in a few stages then another 90 degrees or something? Very tight, feels like they really tension up. Wouldn't be surprised if I was up around 300NM by the time I hit 90 degrees of rotation.
So I'm weary of re-using those. My workshop manual says replace each time, others on this forum say a single re-use is OK, and I think that's as far as I would go with them personally. Have you ever seen pulley bolts snap, or do they really stand up to multiple re-use?
APH wrote:
Ford Spec says they can be re used three times, you should centre punch a dot into the heads each time you remove them, and then you know when they need changing. I have never had a set fail on re use, and I've done a lot of chains and pumps over the years and always re used, and have my own vans ones out about 5 times now, and still haven't replaced them! although they are probably cheap enough so could get a set if you feel happier. I do have trouble with the front cover bolts though, as they snap really easily if not careful. I just finger tight and about a quarter turn with a small ratchet now and that's it, provided sealer bead is correctly done, and you didn't mangle cover when removing it, then it won't leak.
Andy
APH wrote:RayTrans wrote:Lads is this a good price as I bought a Mk6 2.4 Rwd Genuine Ford Timing Chain, Genuine Ford Tensioner, and Guides for £355 pounds
Not a bad price, but not sure if all dealers use same prices, as whenever I've got the bits for a RWD van, I alway got from fords, and only ever cost about £340, however, I got the following every time, and I wouldn't recommend doing it without the bolts etc as they are stretch type and can snap if re used...
Parts I ordered where:
Guides,
Tensioner
Tensioner Blade
Guide Bolts / blade bolt
Tensioner bolts
Chain
Front cover sealant
Gasket for front cover coolant elbow (metal triangular gasket)
Coolant elbow O-Ring
Water pump to Block gasket
Andy
