Water build up in passenger door step wells. (see pic)
Postby Mackiebob » Wed Jul 12, 2017 11:50 am
Is this a common problem with the MK7 Transits? I wonder if my weather seals are damaged because the wells seem to fill up whenever it rains.
Any suggestions on fixing this? I'm tempted to drill some drainage holes.
Thanks in advance
Mack
...note. I have removed the weather seals for the purpose of this photo. There is a join at the bottom right by these wells which makes me wonder if the seal is supposed to be all one piece...
Mackiebob
Re: Water build up in passenger door step wells. (see pic)
Postby gt_addict » Wed Jul 12, 2017 9:30 pm
No photo thanks to photobucket being d*cks about photo hosting.
gt_addict
Postby bigjohnthomas » Wed Jul 12, 2017 9:33 pm
You can upload the pic straight to the forum
Use The box down below :o
bigjohnthomas
Postby tibsy » Thu Jul 13, 2017 5:23 am
Take a look here-
viewtopic.php?f=2&t=156644
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby mr_so » Sat Jul 22, 2017 1:02 am
Same problem and yet to find a solution, the foam under the rubber mat gets soaked and i have to take it all out to dry it, opening up the drain holes doesn't help that as it's already wet by the time the water runs down there :| seems to come in somewhere above and runs down the wheel arch then down into the step well. My best guess ATM is the door seal but I can't find where the water is getting in...
mr_so
Postby ned » Sat Jul 22, 2017 8:21 am
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby mr_so » Sun Jul 23, 2017 12:48 am
nedforceone wrote:This might help
viewtopic.php?f=5&t=181029
I'll check it out and fill those holes, thanks :)
mr_so
Postby Tranny'se Boy » Mon Jul 24, 2017 11:09 pm
My mk6 had the same and it was coming from the furthest roof joint by the back doors then down the arch and all the way to the bulkhead underneath it and into the wells. I have sealed the dodgy joint with wetrooms liquid membrane and no more water.
Sent from my SM-T580 using Tapatalk
Tranny'se Boy
Users browsing this forum: Google [Bot], knobby1
