I bought a 2007 2.2 non runner from an auction and now I'm in the process of getting it going
It will start up on cylinders 2 and 4 when I pull c1 or c3 the van won't cut out or change but when I pull c2 or c4 it will die immediately I've swapped about the see of its an injector problem but all are good
I've tested the power to the tops of each injector
Power to c2 and c4 but not to c1 or c3 I tested with a multimeter when cranking her over
Has anybody else experienced this?
Has anybody got a wiring diagram?
How should I go about testing?
Any help much appreciated I will post the problem and solution to help anybody else after it's solved
Thanks in advance
