by oOplumberOo » Thu Jul 20, 2017 10:01 pm
i did this , i used sheet metal , i literally ran the grinder straight across about 4-5" above the floor level all the way around the arch , bent up a piece of sheet metal for the two corners and over lapped it on this inside at the top and it shot straight down , hard to explain, at the time it was easier for me as my floor was out i also added a piece of angle iron that took the load across direcetly below the arch line {where arch meets floor} , and then plug welded to that from the inside of the arch ,
