Fitting Runlock To MK7 2012 Transit
Re: Fitting Runlock To MK7 2012 Transit
Postby mjsroofing » Wed Jul 26, 2017 10:15 am
dumper wrote:If I was going to use one I'd also get a disco lock for the stearing wheel to put off any one thinking they'd just breaking in and drive off easily with the run lock you may not loose the van but it may stop you losing a side window and may also keep plod happy
That's a good idea , you always have the chance if someone trying their luck.
www.mjsroofing.co.uk
2009 2.2 tdci 115ps just over 51k and sweet as a nut ( so far )
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Postby matthew2riches » Wed Aug 09, 2017 2:49 pm
So does anyone know if a few relays and offcuts of wire would be ok or do i need to buy a new fangled box of wizardry?
Thanks :D
matthew2riches
Postby loot » Wed Aug 09, 2017 3:07 pm
A switch with led on and a couple of relays will work, it will work on the principle that the switch bypasses the ignition switch wire to mimic the ignition switch in the on position but you'll have n/c switches on the handbrake/clutch whatever safety you need and when they are deactivated they'll Curt power to the switch to cut off the ignition.
There are a few ways to do it.
Ids map here
loot
Postby MB15 » Wed Aug 09, 2017 9:57 pm
I emailed this company to enquire about their £44 fancy box for my 2012 van
http://www.rsg-ontop.com/shop/100_Run_Lock_Systems
"I am sorry to say that it is unlikely to work.
We would recommend using a vehicle specific CAN-based run lock system
in order to ensure that the part is effective
The Mk7 is £159.00 exc. VAT (3-5 working day lead time).
No extra Relays are needed for the install, just a momentary Switch which are £24.00.
Please note that the remote central locking will not work when in runlock but the central locking still works by using the key in the door"
I`m planning doing similar to what Loot has said tbh, I have a friend in the ambulance workshops so hoping to get a rough wiring diagram "print out" before i touch anything (I`m shite with the wires)
2.2 - FWD - 2009 - SWB
MB15
Postby mjsroofing » Thu Aug 31, 2017 9:05 pm
The runlock I have is just two relays and some diodes, I think on relay would work if you don't have the cut off switches connected to the clutch pedal and handbrake.
Jls on here sold me mine
mjsroofing
Postby MK7 user » Fri Sep 01, 2017 12:47 am
dumper wrote:But are they road legal is it not an offence to leve a unattended vehicle running on the public highway
Correct-O-Mundo....Highway Code Regulation 123. :wink:
There are some exemptions, such as a Utility Contractor using work tools via a PTO....
I understand that if you do jail time, there is a high probability you'll be gang raped....I also understand they do a good English Breakfast, so you may want to risk it. :mrgreen:
No Squire, not just any van....it has to be a Mk7 (VM.1) :D
MK7 user
Location: Grim HQ in the parish of Aston Nr the Great Hall
Postby misterdog » Fri Sep 01, 2017 8:35 am
I'm not sure , but if a correctly fitted runlock is fitted, which deactivates if you press clutch, brake panel of release the handbrake then I think it's OK because nothing can be done to the unattended vehicle.
No it's for environmental reasons. Global warming and air pollution.
The taxi rank at our train station often has 20/30 taxis, imagine if they all left their engines running....
2002 Mk6 90 T350 2.4TDDI
misterdog
Postby dumper » Fri Sep 01, 2017 8:46 am
Sod the environment just keep supping diesel :lol: :lol: :lol:
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby loot » Fri Sep 01, 2017 10:05 am
Don't see the yanks giving much of a fook.
All be driving hover cars by 2040 anyway :-)
If it's that much of a worry you can fit a cheap remote relay that you can turn off if you spot the feds :mrgreen:
Such negativity chaps :shock:
Ids map here
loot
Postby misterdog » Fri Sep 01, 2017 11:29 am
dumper wrote:Sod the environment just keep supping diesel :lol: :lol: :lol:
No law against that, so long as you are not parked up with your engine running :mrgreen:
misterdog
Postby karl » Fri Sep 01, 2017 12:13 pm
karl
Tranny Lover!!!
