Steering wheel cover ?
Postby Marauder » Fri Jul 21, 2017 8:40 am
2008 swb 2.2...... Any body know of a good steering wheel cover. My Steering wheel is looking a bit crap. I don't wana go to all the trouble of replacing the wheel. So a cover which has some sort of thred to run around its inner edge to keep it on tight will be ok.
Ford Transit 280 SWB,,Year 2008,,2.2,, If it can,t be fixed/repaired/ with a 4 pound lump hammer then it must be an electrical problem.
Marauder
Re: Steering wheel cover ?
Postby bigjohnthomas » Fri Jul 21, 2017 10:24 am
Its not that bad changing the wheel you know
Socket, mirror, pokinthing half an hour ?
You can get a nice leathery wheel for it
Or one of these
https://www.ebay.co.uk/itm/201961728993
bigjohnthomas
Postby ned » Fri Jul 21, 2017 10:34 am
I like them steering wheel covers from the '70's and '80's you know the ones that had the lace around them. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Marauder » Fri Jul 21, 2017 4:29 pm
Ok what cars steering wheel fits straight on to my Transit 2008 2.2. Is it a case of undoing a couple of screws underneath the s wheel to remove airbag ? Then undo the big centre nut ? Any info Guys.
Marauder
Postby adam75pl » Fri Jul 21, 2017 6:22 pm
Marauder wrote: Any body know of a good steering wheel cover. My Steering wheel is looking a bit crap.
http://www.ebay.co.uk/itm/FITS-FORD-TRA ... 1438.l2649
This post only expresses opinion of the author of today. It can not be used against him tomorrow, or any other day following that date. In addition, the author reserves the right to change his views, without prior notification.
T280 SWB 2.2 115PS
adam75pl
Postby bigjohnthomas » Fri Jul 21, 2017 7:22 pm
Marauder wrote:Ok what cars steering wheel fits straight on to my Transit 2008 2.2. Is it a case of undoing a couple of screws underneath the s wheel to remove airbag ? Then undo the big centre nut ? Any info Guys.
Spring clips to get the air bag off not too bad think I used the camera on my phone to see them
Then the center but easy enough really
Think its a later c max one you want
Gentleman don't have steering wheel covers :D
bigjohnthomas
Postby wronghole » Fri Jul 21, 2017 8:22 pm
Amazon or eBay do stitch on ones , real leather in different colours.
wronghole
Postby EDDY99 » Sat Jul 22, 2017 7:50 am
MK 7 Transit 2006 (56) 2.4L Duratorq-TDCi (100PS) Series 1.7-350L
EDDY99
