Rewiring Cigar Lighter
Postby nottery » Fri Jul 21, 2017 8:40 am
Hi there,
I noticed that the cigar lighter wasn't working, so i traced it back to the passenger fuse box, specifically fuse 58 (20A) cigar lighter. What has happened is one side of the connector that the fuse blade goes into has broken off (popped through). My question is, what would be the best place to get another 12v from? I was thinking i could get it by splitting off the 12v constant wire on the radio. What would you guys do in this situation?
Have found this forum to be a valuable source of information,
Thanks Nick.
2006 ford Transit, MK6, LWB, High top, Ex-Postie Van.
2006 Ford Transit Diesel, Mk6, 125 T350, DuraTorq-Di, D0FA
nottery
Re: Rewiring Cigar Lighter
Postby the dutch guy » Fri Jul 21, 2017 2:08 pm
don't hook the lighter up to the radio, you wil burn out the wires when you load the lighter plug up.
grab the main input of the fuse box, made a decent splice (solder, don't use those stupid clamps that cut into the wire) and put in a new 20A capable fuse in line as a replacement fuse.
or get a new fuse box from a scrapper.
Mk6 SWB TDCI 125
the dutch guy
Postby loot » Fri Jul 21, 2017 2:11 pm
Just to be clear, the terminal behind the fusebox that the spade fuse pushes through has failed yes? So you only have 1 spade showing?
Generally the top spade goes to the bus bar and the bottom spade goes to the output/device/light whatever. which spade has gone?
If your spade got hot and broken then it must have been loose and arcing out slowly heating up and burning.
Post a picture would help :-)
Ids map here
loot
Postby nottery » Sun Jul 23, 2017 7:16 am
Thanks All for the replies.
Sorry i'm not sure about all this terminology, when you say spade, are you referring to the thing that the fuse blade goes into. If so yes, there's only 1 showing, the bottom connection.
I'm not sure where the main input of the fuse box is, i'm good with soldering, wouldn't use crimps for this.
I managed to slide the passenger fuse box out (not very far), but couldn't find any loose wires that had popped out from behind.
It looks like there is a bit of plastic that has broken off that was holding the female terminal in place. Probably from me sticking multimeter probes into. (oops)
Not sure about replacing the fuse box,
I've attached a picture.
Thanks again everyone for your input, Nick
nottery
Postby dumper » Sun Jul 23, 2017 8:22 am
My van been a camper van I rewired both cigarette plugs to the leisure battery and fuse box you could maybe run a fused wire from your battery if you don't want it live all the time also put a switch in line
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby loot » Sun Jul 23, 2017 9:37 am
Can you confirm that it isn't just missing? Some vans don't have all of the fuses available, also some fuses have been marked down wrong in the technical info.
So, if you can see the terminal inside or if someone with a mk6 can confirm the fuse number is correct?
Typically to repair it or add it you'd split the fusebox and add it, you can either go to the main power bus bar or find a wire that goes to the bus bar and splice to it.
I wonder tho if that fuse is the cigar lighter 1 and if they were an option on some??
Ids map here
loot
Postby nottery » Sun Jul 23, 2017 11:38 am
Will have another look tomorrow to see whether its missing or just popped through.
I'm currently in the process of converting it to a camper, so, at this stage will most likely rewire from the leisure battery.
Would someone be able to help me identify the (Main power bus bar), what it looks like?
Thanks all, Nick.
nottery
Postby ned » Sun Jul 23, 2017 11:51 am
This might help identify the fuse
viewtopic.php?f=40&t=71739
Cigar lighter fuse 212 10amp incab fuse box. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Sun Jul 23, 2017 12:05 pm
nottery wrote:Will have another look tomorrow to see whether its missing or just popped through.
Thanks all, Nick.
It is the main power feed to most of the fuses, 1 leg of the fuses will be bus and the other leg will be output from the fuse. So say the top leg/pin will all be going to say a main 60a fuse. And each of the bottom legs go to the device it is powering but the fuse is rated for the required load, cigar is 10A according to Neds post.
Yes? :-)
Ids map here
loot
Postby dumper » Sun Jul 23, 2017 12:19 pm
As loot said mine didn't have it in the fuse box I think that was another reason I wire to the leisure battery's it was 8 years ago when I did mine so not to sure why I did it :lol:
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby nottery » Sun Jul 23, 2017 12:47 pm
I think i understand loot.
Here's a photo from my Haynes Manual 4775 (X to 56 reg), its numbered differently but fuse location is the same.
Thanks Again, Nick.
nottery
Postby nottery » Sun Jul 23, 2017 1:57 pm
Just found this post from a few years ago,
viewtopic.php?f=5&t=96039,
Looks to be the same issue i'm having, will have a good look tomorrow.
Might try looking at fuse locations that are stated as 'not used' ( ie. F50 & F64 ) as i took the fuse blades out of them.
Thanks Everyone for your help :D
nottery
Postby nottery » Mon Jul 24, 2017 4:40 pm
Just an update on this cigar lighter fuse issue.
So today i put fuse blades back into the spots on the Passenger fuse box that were stated as (not used) in my Haynes Owners Workshop Manual (4775),
to be more specific, F50 & F64.
And VOILA , Cigar lighter is now Working!. along with rear wipers.
Fuse 50 was the Cigar Lighter
Fuse 64 was the rear wipers
Thanks Everyone for your help!
Hope this helps someone else in the future.
Nick.
nottery
Users browsing this forum: Google [Bot], TheCake
