by Hethaz » Sun Jul 23, 2017 10:54 pm
Hi I have just joined Forum I have viewed for many years and it's been great help for solving problems and learning new things and so decided to join as I am looking for some help, I have a 2007 mk7 115ps with big end gone, I have found someone to put a mk6 90ps tddi replacement engine and wiring harness/clocks in, but using the mk7 6speed box. Van is up and running fine, no problems and was the only affordable option I had to get van back on road. The problem is the speedo does not work, they man has done conversions before and had no problems with a 5 speed box. Is it possible to fix or is speedo fed from abs rings on mk6? Clocks are digital and worked in mk6. The engine came from a 2006. Any help would be massively appreciated, thanks
