Hi from Aus,
Today my 2008 110 fwd had a miss going up hill and threw these codes
P048014 - fan 1 control circuit
P00897A- fuel pressure regulator performance
P068A00 - ECM/PCM Power relay deenergised too early
P116E00 - fuel pressure relief valve actvated
Is this meaning I need to replace SCV & PRV or was it just a hiccup?
Live data for fuel pressure at idle does fluctuate slightly at start up then settles @23
Also is g scan2 capable of doing pump & pilot learn?
Thanx for any help as haven't found any transit gurus on the sunshine coast
