Duratec 23 ECU Pinout.
Postby sparkyguy » Wed Jul 26, 2017 12:32 pm
Does anyone have, or have access to a pin-out diagram for this vehicle?
Although I have quite a few resources at hand here in Australia, I can not find exactly what I need. The petrol models are not common here.
Hoping somebody can help. :)
DETAILS
WFOLXXGBFL1D84488
Transit 2000-2006, 2.3L DOHC (145PS), Diamond White 73
Primary Features
Build Date: 13.11.2001
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van
Series: 1.7-350L Series Engine: 2.3L DOHC (145PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.6 Emission: 2000 EEC (EEC 7)
Air Conditioning: Manual Air Conditioning
Territory: (+)"AUS" Paint: Diamond White 73
sparkyguy
Re: Duratec 23 ECU Pinout.
Postby v8dave » Wed Jul 26, 2017 7:35 pm
Ecu pin-out as requested.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby sparkyguy » Thu Jul 27, 2017 3:16 am
Woo-Hoo. Thanks so much v8dave.
That's a good start, however I have no way of knowing what the designation codes on the pins represent. [ e.g. 91S-RH15 on pin 1 ]
I suppose they might be same as in other models, but such things are not necessarily so.
Don't suppose you can help with that also ?
[sorry to be a pain] :|
sparkyguy
Postby v8dave » Thu Jul 27, 2017 8:41 pm
It's 91s not 915.
OK the codes.
Simple bit first, wire colours are in the brackets - background then trace if appropriate.
I don't know what the first part of the code relates to for sure.
However the first part of the code should relate to the circuit number.
91s appears to be the ignition coil low volts.
Unfortunately I can't find a list at the moment.
The second block of the code, that is after the hyphen refers to where the wire goes.
From the ford info
RA - Connectors
RB - Destination notes
RD - Diodes, fuses, indicators, resistors, heaters
RE - Modules, controllers
RG - Motors
RH - Relays
RJ - Sensors
RL - Solenoids
RN - Splices/Busbars
RP - Switches
RR - Transformers
RS - Units
If you look at pin 55 it has a code RE21, and it connects to fuse 21 in the battery junction box.
Will keep looking for a circuit list.
v8dave
Postby sparkyguy » Thu Jul 27, 2017 10:14 pm
Thanks v8dave.
sparkyguy
Postby midnight » Sat Jul 29, 2017 8:51 pm
Hi, Would anyone have a pinout for the ECU on a mk7 2.3 Duratec 2007 which is also petrol. My ECU is a later one so unfortunately the pinout above does not cover mine.
Vin: WF0XXXBDFX7E05353
Ford Transit mk7 2007 145 T300 mwb shr rwd petrol/lpg
midnight
Postby v8dave » Sun Jul 30, 2017 12:19 pm
midnight wrote:Hi, Would anyone have a pinout for the ECU on a mk7 2.3 Duratec 2007 which is also petrol. My ECU is a later one so unfortunately the pinout above does not cover mine.
pm me your email address and I'll send you the image for the ecu wiring.
v8dave
Users browsing this forum: Bing [Bot], Google [Bot], gt_addict
