by grogan197 » Fri Jul 28, 2017 11:50 pm
Easy fix on a MK6. You can either buy a new fob on ebay for about £3 last time I checked, or you can try to program yours in to the ecu again on the off chance it works.
The programming procedure is:
– Insert a programmed key into the ignition
– Turn the key from the off to on position 8 times
– You will hear the vehicles locks cycle
– Press any button on the remote
– Again you will hear the locks cycle
– Turn the key to the off position and remove from the ignition
– Wait 10 seconds and test the remote
If you have more than one remote to program you have to do it at the same time as it looses all previously known remotes when you program a new one
