MartinWillmott wrote:I did the learn on the pump, no one can fathom why the dealer tried to learn the injectors! There is no fault except the injectors can't be learned in, simply because they were done when fitted and over the years tolerances have changed, that's why the ecu won't allow the codes to be re learned, it knows the codes are no longer valid due the the added mileage, they all need to be re-encoded or replaced, they can only be re-encoded on a delphi machine and would probably need to be reconditioned to do it, what would be the point in learning injectors on the original codes if they've done substantial mileage? they'd be worn past the code's spec. So it makes sense, even if they were learned in now they'd be out of tolerance fom the time they were encoded, thus the ECU won't accept a re learn on them, and they cant be erased and even if they could and then learned in the tolerances relating to the codes on them are well and truly past their sell by date so it would be miles out anyway. the dealership unlearned the injectors now the ecu wont accept a new learn and for obvious reasons,
they were working fine up to the point the dealership unlearned them now the ecu has no idea of tolerances or wear on the injectors so it throws a light and runs rough.
It was running fine with no light on when I took it to the dealerhip, they said they'll contact Ford to see what they're prepared to do about it, but Ford didn't screw it up, neither did I, the dealership did, so once again, who should pay to sort this out
Ml Autos wrote:MartinWillmott wrote:I did the learn on the pump, no one can fathom why the dealer tried to learn the injectors! There is no fault except the injectors can't be learned in, simply because they were done when fitted and over the years tolerances have changed, that's why the ecu won't allow the codes to be re learned, it knows the codes are no longer valid due the the added mileage, they all need to be re-encoded or replaced, they can only be re-encoded on a delphi machine and would probably need to be reconditioned to do it, what would be the point in learning injectors on the original codes if they've done substantial mileage? they'd be worn past the code's spec. So it makes sense, even if they were learned in now they'd be out of tolerance fom the time they were encoded, thus the ECU won't accept a re learn on them, and they cant be erased and even if they could and then learned in the tolerances relating to the codes on them are well and truly past their sell by date so it would be miles out anyway. the dealership unlearned the injectors now the ecu wont accept a new learn and for obvious reasons,
Ok. give us a reading of fuel pressure at idle, reading of fuel corrections.
try to do ppi yourself. sometimes it takes couple of attempts.
"You can't learn in the existing injectors, the learn process can only be done with injectors after they or the ecu has been replaced!
BUULSHIT
loot wrote:I have learned injectors that are over 100k.
a good injector will always pass the learn function.
Yours has failed because of reasons I've already said.
We are here trying to save you money, where as the garage aren't.
It is upto you which course of action you want to take but you'll end up reading the whole of this post again after spending lots of money and think, oh, they're not all c**s after all.
MartinWillmott wrote:Ml Autos wrote:MartinWillmott wrote:I did the learn on the pump, no one can fathom why the dealer tried to learn the injectors! There is no fault except the injectors can't be learned in, simply because they were done when fitted and over the years tolerances have changed, that's why the ecu won't allow the codes to be re learned, it knows the codes are no longer valid due the the added mileage, they all need to be re-encoded or replaced, they can only be re-encoded on a delphi machine and would probably need to be reconditioned to do it, what would be the point in learning injectors on the original codes if they've done substantial mileage? they'd be worn past the code's spec. So it makes sense, even if they were learned in now they'd be out of tolerance fom the time they were encoded, thus the ECU won't accept a re learn on them, and they cant be erased and even if they could and then learned in the tolerances relating to the codes on them are well and truly past their sell by date so it would be miles out anyway. the dealership unlearned the injectors now the ecu wont accept a new learn and for obvious reasons,
BUULSHIT
So every garage that has looked at this and said the same is wrong, that's 3 garages one of which is a diesel specialist doing nothing but diesels, and you're right? let's look at the logic of learning in the original injectors which may have done 130,000 miles since they were fitted, the learn process on injectors is a one shot process simply because when they are fitted the codes tell the ecu the parameters, over the years and miles the ecu compensates for wear so here we are trying to learn injectors as if they're new but with up to 130k on them, would the parameters still be accurate after that sort of use and wear? no! that's why the ecu is forbidden by it's own software to re-learn injectors, it makes perfect sense, The socks you wore at 6 years old wont fit you as a adult will they so why try? and before shouting profanities show me some proof that these experts are wrong and you're right.
Users browsing this forum: Craig_sg
