stevezz1 wrote:MK7 Transit 2012 260 swb 100 2198cc
Hi All,
the esp and powertrain warning lights came on last week resulting in a loss in power.
Portable diagnostic reader pointed to glow plugs, just had these replaced but the lights have come on again after about ten miles.....
Any help is greatly appreciated.
Cheers,
Steve.
Any joy with this Steve?
I have the same issue with my Mk7 2013 XLWB.
I have had the intercooler pipe replaced as it had a split in it, Glow plugs and 5th glowplug replaced, EGR valve replaced. I have now been informed that the turbo needs to be replaced as the vanes are not actuating causing too much boost pressure. Fault code is P2599. Not sure if this is the case as the van drives great but at about 80 miles the fault lights come on and the van goes in to limp mode if I switch engine off then on again the fault lights clear and the van drives like new again.
