APH wrote:The blue unit has no alarm, the orange one does. The ford alarm DOESN'T sound the horn, it has a separate sounder. It sounds more like you have a problem with the wiring around the steering column / ignition switch as the key in / out of the lock doesn't have a switch on these vans, so if its quiet even with ignition completely off and only stars sounding when you pull the key out the hole, id start looking there for a pinched wire around the steering lock area.
Andy
Keef wrote:Don't know about Mk6, but Mk5 factory fit alarm has horn inside both front doors so they are probably the same.
Punto443 wrote:I recon it's a wiring fault and the horn sounds when the key is removed as it's earthing itself through the steering lock when the pin pops in to lock the wheel in place.
May just be the horn push it's self.
