MK6/7 seat trim removal
Postby Hovervan » Thu Aug 17, 2017 9:53 am
Hello chaps,
we finaly managed to grab a cheap single passenger seat *yes*, probably its from a MK6 because other canvas decor that my mk7 has but console seems to be identical.
But two large problems:
1. this seat stinks as hell and is dirty :shock:
2. we want to go on holidays on sunday
Has anybody an idea how complicated it is to remove the whole seat trim? I think our only chance is to put it in the washing machine.
Please help, my lady doesnt want to to 2000km single way on the shitty dual seat bank :oops:
Hovervan
Re: MK6/7 seat trim removal
Postby Punto443 » Thu Aug 17, 2017 10:55 am
I've removed the seat covering a few times to instal heater pads.
They're fairly simple if you work methodically, the metal "pig rings" need prised apart to remove. But instead of mucking about trying to refit them, use cable ties on reassembly. There is a metal rod incorporated into the foam to tension the middle seam lines, don't put too much pressure on this, as it can pull apart from the cushion.
After removing the headrest, the plastic tubes twist 90 degrees and pull out from the top.
The arm rest unbolted from the pivot with a torx bolt.
I'm sure on the bottom of the backrest there is two plastic channels that slot into each other to secure.
If the base it really bad, the covers can be bought for about £40 on eBay I'm sure. :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby Hovervan » Thu Aug 17, 2017 4:01 pm
Thank you Fiat-man! :D
(I have a Panda 4x4 for hunting & fishing, great car!)
Hovervan
Postby dumper » Thu Aug 17, 2017 8:54 pm
At work we use a katcher wet vac to clean the bus seats it cleans them really well
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby richgold » Fri Aug 18, 2017 6:28 pm
Its likely that if you machine wash the cover it will shrink and not go back on the seat.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby ake » Fri Aug 18, 2017 10:53 pm
richgold wrote:Its likely that if you machine wash the cover it will shrink and not go back on the seat.
Only if the washing machine is on a hot setting.
I've done this many times, without a problem
40 deg c is king!
