grogan197 wrote:Whilst trying to measure the runout on my brake discs and thinking I was in neutral I gave the hub nut a spin with a breaker bar to spin the disc as the pads were sticking to the rust. I went to put it in first so I could loosen the brake disc bolts and found it was already in first
All of my gears now act like neutral. So what have I done and how the hell do I fix it?!?
grogan197 wrote:The shifter feels like normal, I had a look and the gear selector cables are all in place and I tried selecting gears by moving the selector arm which makes no difference
I don't seem to have much luck with this van
grogan197 wrote:I just had another look and there is a small change in resistance between idle and it being in gear so maybe it's a problem with the clutch as the wheels are connecting to the gearbox but not to the engine...
grogan197 wrote:The clutch is fairly new to be honest so shouldn't be worn. I'll have a look at the slave cylinder and see if anything looks unusual there.
The selector should be fine as I only replaced the bearing, seal and bush a month or so ago.
grogan197 wrote:I just gave the engine a start and there is a twitch of movement on the drivers side wheel when I engage the clutch. The passenger side wheel spins but i'm not convinced it spinning at an consistent speed
grogan197 wrote:I did a test turning the wheels and turning one clockwise should make the opposite wheel go anti-clockwise but they both go clockwise. I'm guessing that means whatever connects on to the driveshafts in the gearbox has come out of alignment...
